I just upgraded a test system to JIRA 7. There was a deactivated Service Desk installation on the system. Now I don't seem to be able to remove Service Desk from the installation. I removed it under addons but that doesn't seem to have actually removed SD. I guess I want to convert my JIRA Service Desk + Software installation to just "JIRA Software".
Is there a way to do this?
JIRA 7 created the new concept of Application that, technically, comprises 1 or more plugins, and has an specific license. Atlassian launched JIRA Core as the basic JIRA System, and Software and ServiceDesk as applications. The new UI to admin those applications and licenses are under System/Applications.
Hello Seb,
You can install/uninstall JIRA Service Desk and/or JIRA Software in the following path: JIRA Administration > Applications.
From your description, it seems that you have some projects associated with the Service Desk, so you can change the project type to Business or Software (Assuming that you have JIRA software installed).
