Jira 8.4.2 and postgresSQL 10.5
Óscar Ramos October 15, 2019
We have Jira 8.4.2 installed on our server with a database of postgreSQL 10.5 and we still have not had any problems. Why does a compatibility error appear between the two software?
Thanks in advance,
Best regards.
Tarek Riahi October 15, 2019
Supported platforms for Jira 8.4
Understanding the Results
Impact
We don't test JIRA with any unsupported databases, so there are no guarantees they will work. Using an unsupported database is considered high risk because if there are problems with the database or unexpected behaviour in the application we won't be able to help you fix it.
https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html
Óscar Ramos October 16, 2019
Hi Tarek,
First of all, thanks for answering my question.
Will you check compatibility between programs in the future?
Thanks in advance,
Best regards! :)
Tarek Riahi October 16, 2019
Make yourself a watcher to these following links below:
Support for PostgreSQL 10 - Jira
Support for PostgreSQL 11 - Jira
Support for PostgreSQL 10 - Confluence
Support for PostgreSQL 11 - Confluence
When the issues changes status to 'Awaiting release' then hopefully you will have a fix version.
Br, Riahi Tarek
