i want to get the results of a filter over the api and save the results in a textfile.
when i executed the api call i get several information but i only need the issue-id.
curl \
-u xxx:xxx \
-X GET \
-H "Content-Type: application/json" \
http://localhost:8080/rest/api/2/search?jql=type%20%3D%20Bug%20and%20resolution%20is%20empty
how can i do this? i'm new with handling the api of jira
best
toni
Hello @Antonio D_Errico
You have to use the fields parameter
ok thanks but that is still too much info.
{"expand":"names,schema","startAt":0,"maxResults":50,"total":1,"issues":[{"expand":"operations,versionedRepresentations,editmeta,changelog,renderedFields","id":"10402","self":"https://tsjira.novatec.net/rest/api/2/issue/10402","key":"TEST-4"}]}
i only need the issue-id (here TEST-4)
Help us plant more trees
