×I've been following the Jira HelloWorld documentation here:
https://developer.atlassian.com/server/framework/atlassian-sdk/create-a-helloworld-plugin-project/
Ran the Atlas-run command which ran without issues.
When I go to localhost:2990/Jira I get a screen saying Jira had problems starting up.
The error message beneath reads:
Can you help me troubleshoot this so I can log-on to the server correctly.
I'll include an image with the full list of plugins that failed to start.
It works as expected in most of cases, so you should check all the general requirement:
My Java version is 10.0.2, do you know if that version is supported?
I'll look at disk space & Ram although I don't think this would be the cause.
Thanks for the reply.
No, Java 10.0.2 is not supported at the moment https://developer.atlassian.com/server/framework/atlassian-sdk/getting-started-tutorial-faq/
