I have my automation rules written in production , however its getting copied to my Testing environment and end up creating false alarms to audience.
So I'm trying to do a condition check using two options , Both not working
1. To check for {{baseurl}} before triggering the alarms to audience.
2. To check for {{issue.url}} starts with "https://jira.perf"
Hello @Boofem
Smart value is just {{baseUrl}} , not {{issue.baseUrl}}.
Please log it first to verify and then include that in your If condition.
You can check against a known part of the URL.
For example, extract string before abc.com like below:
{{baseUrl.substringBefore(".abc.com")}}
and then check if that equals
worked when I tested locally.
Awesome. Please consider accepting answer so it benefits others. Thanks!
