Jira CVS Importer
Bruno Araujo June 18, 2013
I'm currently evalueting JIRA and when i try to import project file i keep getting the following erro "Cannot attach file export.csv: Unable to communicate with JIRA.". I've looked over the tomcat log, the jira logs but none of them show any kind of error.
What am i missing here?
Balavinayagamoorthi
It is working for me now when i enable all the modules in "jira importer plugin" in manage apps section.
Balavinayagamoorthi
I get the same issue in one of my test instances of Jira.
But the same file is working fine in Prod instance.
Faisal
June 18, 2013
Dear Bruno,
So as I understand it, you are trying to import data from CSV file into JIRA, can you kindly confirm this? Anyway, may I know what are the steps taken to import the CSV data into JIRA? Kindly let us know and we will look into it.
On a related note, perhaps the following documentation may help:
- https://confluence.atlassian.com/display/JIRA060/Importing+Data+from+CSV
Ahmad, Thanks for your reply.
I'm trying to import a project in CSV format into JIRA using the 'Import External Projects'. On the very first step were i'm asked to point the file to import i get the message i've said before.
I've checked the attachment configuration and its enabled; The user that is running the JIRA process have suficient permition to create/edit files in the attachment folder.
