Can someone please tell me how to go further after this step??
There is no place to add the new key and nothing is appeared when i click the other radio buttons...
Is it because, i am running all this in a localhost (test env.) ???
Thanks in advance!
It should be nothing to do with localhost or testing - there should be buttons after the radio-buttons that you can click after selecting one of the three options.
Could you try refreshing the page? A different browser? Are there javascript errors anywhere?
Thanx a lot @Nic Brough -Adaptavist-
The problem was because of the browser! I used chrome before....
With Firefox eveything seems to work ;)
