Jira - Cron expression
Gavin
July 5, 2021
So I have the following cron expression
00 9 * * * ?
which I thought was run this everyday at 9 am
But based on the email I've been getting
  • It's every hour at 9th minute of the hour
Followed: https://support.atlassian.com/jira-software-cloud/docs/construct-cron-expressions-for-a-filter-subscription/
What am I doing wrong?
10 votes
Dirk Ronsmans
Hi @Gavin ,
That expression will indeed translate to
At second :00 of minute :09 of every hour
The expression you would want is: 0 0 9 ? * * *
That translates to: At 09:00:00am every day
You can easily generate these by using an online tool, for example: https://www.freeformatter.com/cron-expression-generator-quartz.html
Anissia Bouesso
November 1, 2024
What if I want the rule to run everyday at 11:30?
Dirk Ronsmans
@Anissia Bouesso if you look at the link I provided you can see it would be
0 30 11 ? * * *
Like • Anissia Bouesso likes this
