Is it possible to have the values of a listbox be different depending on what step the issue is in?
For example, if the issue is in the Open step, the values of a custom field "Sub step" is A, B and C. If the issue is in step In Progress, the values of a custom field is D, E and F.
I think that there's no standard way to achieve this, maybe you can try with an script custom field using ScriptRunner.
A scripted custom field won't help - they're read-only (unless sub-step could always be calculated, not entered by the user. Then they're ideal) But I'm pretty sure you can do it with Scriptrunner.
I have not tried it myself, hence I'm not 100% sure, but, define the sub-step with values A, B, C, D, E and F. Then use a "Behaviour" to remove the options you don't want, depending on the current status.
You're right, i missed the "select list"
