Jira Datacenter Azure
Raj February 11, 2019
     Did anyone go with Jira/Confluence datacenter on Azure. If so what user directories did you configure as it is hosted on the cloud.
Thank you.
Gregory Van Den Ham
Have you reviewed the documentation to deploy Jira Datacenter to Azure?
https://confluence.atlassian.com/adminjiraserver075/getting-started-with-jira-data-center-on-azure-937183335.html
The easiest approach is to install this from the Azure Marketplace and let it automatically install and configure the instances.
root .
May 9, 2019
the problem if follow those steps, is what after finally of deployment, don't can you is login in the instance for http....
neither with the user and password, what you has been defined before and during the deployment...
