Jira - Execute plugin from SIL
FCT_ Malcolm Boekhoff August 21, 2023
We execute the Jira PlugIn "Attach PDF" (Bette PDF) on a transition in the Workflow.
Is there a way to create the attachment using a SIL function and calling that function instead?
Anna Hryhoruk _Appfire_
August 22, 2023
Hello @FCT_ Malcolm Boekhoff ,
Yes, in SIL we have dedicated attachment routines that could add attachments automatically using the path to an attachment or URL, also it`s possible to add attachments from the email. Or add validators/conditions that check if an attachment was added at some point. But if you mean generating some pdf file based on some information - unfortunately there is no inbuilt functionality for that. However, if this can be done using Groovy, you may be interested in combining Groovy and SIL SIL Groovy Connector Running Groovy Scripts in the SIL Manager
Below I am also adding some documentation of what I mentioned above Attachment Routines Hide button until an attachment is added Ensure that issues have attachments
Hope it helps!
Anna
