I would like to find a way using AdaptavistScript Runner how to set a Custom User Picker Field after selecting an Option from a Select List (Single Choice) when creating an issue.
Example: If I choose Product A, I would like the Product Owner to be username1
Can someone please give some tips on how I can set this up?
Cheers
Here is code example for your case. I did not tested it, but it should work:
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.issue.customfields.option.Option String userName; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); switch(((Option) issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Select List"))).getValue()){ case "Option 1": userName = "user 1";break; case "Option 2": userName = "user 2";break; case "Option 3": userName = "user 3";break; } issue.setCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Custom User Picker Field") , ComponentAccessor.getUserManager().getUserByName(userName) )
Thanks a lot for your promt reply,
For some reason, I get this error message:
image2016-10-19 16:17:35.png
What do I need to declare?
What is the context where you are running this, eg a post-function? A screenshot of the whole page would help here.
