Jira - How to add a sub-group or nested-group
Kevin Portlock April 8, 2013
Hi, I have added Confluence to Jira for user authentication. On the Jira server I have added a user to the group confluence-users. I can log into confluence with the user that exists in Jira.
I am unable to figure out how to add the group confluence-users to the group jira-users so that all members of the group jira-users can log into confluence.
When I go to add to the group jira-users I can only see users and not groups.
So I cannot figure how to create nested groups.
It is working. I missed a new link called "Edit Nested Group Members" after I enabled nested groups.
C
April 16, 2015
Could you also change the Global permissions in Confluence to use the JIRA User group as the group to grant access?
Kevin Portlock April 28, 2013
Answered own question in the first answer.
Kevin Portlock April 14, 2013
Posted answer instead of 'Answer Own Question' See post below.
Renjith Pillai
April 8, 2013
Nested groups are not supported, AFAIK. You need to make sure that the user belongs to both groups confluence-users and jira-users if the user is expected to use both products.
