Hey guys,
iam setting up email service system with jira and jeti addon for one customer.
Everything is working fine, but there is one problem.
Currently iam using Imap to get the mail of the customers mail provider.
When Jira finds the mails in takes them and deletes them on the mail account.
Problem is there are completly deleted and not simply moved to the trash folder.
When i delete a mail from the mail account in moves in to the trash folder, so i have no idea what jira is doing.
I think there wont be a simple way to say jira not to delete the mails but to move them out of inbox. But maybe there is a way to say jira to delete them to trash and not completly?
In our mailing server we have the possiblity to directly create a copy of the incoming mail and jira then deletes the mail from inbox, but we still have a backup then.
Our customers mailing service dont offer such possibilities.
Any ideas whats the best possiblity?
Hello All,
I have tried one solution to this , copied the mails to another folder and then used that folder for Jira only.
using INBOX/Folder name in the incoming handler does solve the problem without any deleting original mails.
mail copied to the DUP folder are being deleted which is for Jira only.
Same problem and I couldn't find any way to sort it.
So to bypass the problem, I created a rule to make a copy of the emails to another folder. And in Jira incoming settings I set the incidents to be created from this new folder. This way, Jira is still deleting emails, but the email deleted are not in the inbox folder so I still have them.
I hope it helps someone else!
Hey Stefan,
I guess you do not have the option of not deleting the emails on your mailbox.
According to the documentation:
https://confluence.atlassian.com/jira/creating-issues-and-comments-from-email-185729464.html
So, the best way to achieve this, is to create another mailbox and auto forward the emails you want to handle through JIRA
BR
"On an IMAP mail server processed messages are not deleted but marked as read."
Documentation has been updated, but the functionality still deletes emails (IMAP)
I have the same issue. When on IMAP the emails are still being deleted from the server.
Using secure imap, Jira service desk is permanently deleting a quarter of the mails that are also eventually not on the mail processing log. The rest are on the mails are on the processing log and can still be found on the inbox with the label 'fetched'.
Also, why are email settings added in two places - on Project Settings and Jira System Settings.
