Sign up Log in
Jira Installation
vishal patel
September 12, 2012
Hello Support,
I have taken the trial version of the Jira.I am installing it on tomcat6.0 on windows 7.0. I have referred the steps and tried to configured the Jira suggested on https://confluence.atlassian.com/display/JIRA051/Installing+JIRA+on+Tomcat+6.0. other thing I am trying to configure the database of MSSQL but there is no config.bat given in .war which I have downloaded and after the configuration is completed, when I am browsing the site with http://localhost:8080/jira, it is giving the error that Jira.home not set. I have set the JIRA.HOME in jira-application.properties as JIRA.home=c:/jira as well as set in environment variable in system settings and from the command line as set JIRA.HOME=c:/jira still it is showing the error jira.home not set.
You help will be highly appreciated.
Vishal Patel
FagnerF
September 12, 2012
Hi Vishal,
Regarding your issue type we can fix it doing a very simple setting. Open your file /install/atlassian-jira/WEB-INF/classes/jria-application.properties and type the following:
jira.home = C:\\Jira\\home
Take care, because you are using Windows then you have to type slash (\\) twice to indicate the directory tree. In addition you can check out on it how to configure Jira_Home.
Cheers
Teck-En
September 12, 2012
You have to specified the jira home under edit-webapp/WEB-INF/classes/jira-application.properties before you build the file.
If you have build the file, you might need to set the home directory in that file and then rebuild the file again.
