×Using an internal JIRA server v10.3.1#10030001
we are getting errors when trying to enable SSL connection for the LDAP lookups.
The initial connection to the server passes but when you test a user lookup it fails with the following error:
Hi @Paul Cope
You're not alone, and the bug was fixed in 10.3.3.
ref: https://jira.atlassian.com/browse/JRASERVER-78523
Atlassian's definition of severity levels is based on customer impact. I imagine they chose to classify LDAPS being broken as a "minor" incident because a workaround existed (use unencrypted LDAP instead).
