Sign up Log in
Jira Link Export to CSV
roger Worsley
June 29, 2018
Hi All
We are noticing that  when we export to CSV if we have an issue blocked by a single issue ie one link it appears, but if issue is blocked by two issues ie two links, then column doesnt appear. Is there a work around or fix?
Best
Francisco Oselame
June 29, 2018
Hi Roger,
Would you know if these links on the issues are Inward Issue Links? By default, the is blocked by is an Inward Issue Link where there's a known bug in Jira which doesn't export Inward Issue Links when exporting issues to CSV:
You can view the types of Issue Links on https://<instance_name>/secure/admin/ViewLinkTypes!default.jspa.
Let me know if this helps in your case.
Francisco Oselame
