Hi every one. Need help with SQL query that will return me names of all projects, in witch "SOME GRUP" is not member of "SOME PROJECT ROLE"
Somthing like:
SELECT * FROM projectname WHERE jira-group(or user) NOT IN project-role;
Right answer is:
select projects.pname from jira.project as projects
inner join jira.projectroleactor as pa on pa.PID = projects.ID
inner join jira.projectrole as pr on pr.ID = pa.PROJECTROLEID
where pa.ROLETYPEPARAMETER = "<here my group name>" and pa.PROJECTROLEID != 10800
1080 i got from jira.projectrole and its ID of my needed project role.
That would the SQL Query
select * from jira.project a where not exists
(SELECT pid FROM jira.projectroleactor b where
roletypeparameter = 'USER OR GROUP' and a.id = b.pid)
Thank you, so much. You answer is not absolutely applicable in my case, but it gave me right direction.
Is it mandatory requirement to use SQL only? Could you use REST, for example?
Help us plant more trees
