I am new to Jira Rest API and i am running Jira 5.1. Is it possible to do oAuth authentication process using Jquery ajax from another genric application?
In this link JIRA REST API Example - OAuth authentication step 1 i completed. I am getting error in step 2.
I tried like this:
jQuery.ajax({ //The URL to process the request 'url' : 'http://localhost:8080/domejira/rest/api/latest/plugins/servlet/oauth/request-token', // 'data' : {'username': 'jiraadmin'}, 'type' : 'GET', 'success' : function(data) { alert('Request token is: ' + data); } });
Got error:
"NetworkError: 404 Not Found - http://localhost:8080/domejira/rest/api/latest/plugins/servlet/oauth/request-token"
thanks for the replies.
In the above code the url is worng thats why i am getting 404 error.
Now i changed the code to:
jQuery.ajax({ //The URL to process the request 'url' : 'http://localhost:8080/domejira/plugins/servlet/oauth/request-token', 'type' : 'GET', 'success' : function(data) { alert('Request token is: ' + data); } });
Now the url is ok but i am not getting the "Request token" and the response content size is showing zero .
Hello, this is kinda old but were you able to make it work? I'm stuck in a similar situation
The 404 error indicates that it cannot find any of the REST endpoints at this address. May I ask what url you use for accessing JIRA?
Are you using any form of reverse proxy? What do you get when you access a url similar to this (be sure to edit the issue key and number):
http://localhost:8080/domejira/rest/api/latest/issue/EXAMPLE-1
When i access through browser with this url
http://localhost:8080/domejira/rest/api/latest/issue/169-59
I am getting the issue in json format.
Register today
