×is it possible in the cloud version of Jira to somehow import values into a drop down? for example if i'm adding a new custom field of type "select list" which has over 150 values is there an import mechanism that can be used to populate rather then manually adding.
Hi Saadiq,
I'm afraid you will have to perform this manually, there is no workaround (that I know of nor been able to find) to automate this.
