Is it possible to integrate our JIRA OnDemand with our Azure AD?
It seems like JIRA is missing from this list
https://azure.microsoft.com/en-us/gallery/active-directory/#all
Is there any way we could be able to use Azure AD, e.g. installing OnPremise version of JIRA?
Thanks in advance.
Hi Timo, unfortunatelly this is not possible to be done with OnDemand platform, external user management is a restricted function in this platform. You may consider moving to a local installation where this restriction doesn't exist.
Cheers
Does anybody have an update on this issue?
We have found the following announcement in the Microsoft Marketplace... but does it really work?
https://azuremarketplace.microsoft.com/en-us/marketplace/apps/aad.atlassiancloud?tab=Overview
There is no statement from Atlassian that integration with Azure is supported on the cloud... (as far as I know).
Thank you for sharing your experience!
