I'm trying to create a plugin that adds a menu item which will launch a dialog to get input from the user, which will then be acted on.
Does anyone have pointers to an example or documentation for creating and launching such a custom dialog?
Thanks.
Hi Steve,
If you're familiar with Atlassian SDK, you might know AUI and I would recommend Dialog2 obviously (https://docs.atlassian.com/aui/7.9.9/docs/dialog2.html).
If you're not, then I would advise some reading on developer.atlassian.com starting with:
https://developer.atlassian.com/server/framework/atlassian-sdk/create-a-helloworld-plugin-project/
This will give you an idea on how to leverage many technologies (Atlassian SDK, AMPS...).
Best luck!
Help us plant more trees
