Jira Plugin build failed due to SSL handshake exception
Sajan Kumar Devarakonda April 30, 2019
I'm getting the following exception when I tried to build the project. Previously it didn't throw any issues. Suddenly It started to showing below error message.
Andrew
April 30, 2019
Hi @Sajan Kumar Devarakonda ,
Maybe You made some change of keystore for java? Maybe change JAVA_HOME to other JDK?
Also I see it https://stackoverflow.com/questions/16428098/groovy-shell-warning-could-not-open-create-prefs-root-node
B.R.
Hi @Andrew , I didn't change JAVA_HOME path, and I've followed the steps provided in the link. But it didn't solve the problem. Any help much appreciated!
Andrew
April 30, 2019
Sajan Kumar Devarakonda May 2, 2019
I made it work, It's failed because it's unable to access com.atlassian.maven.plugins. Then I've uploaded *.atlassian.com certificate to the Java key store. Then it started working again. Thanks @Andrew for following up issue.
Like Andrew likes this
Register now
