Jira REST API call using Excel VBA got response error 403 Forbidden.
Kobayashi_Masanao
May 31, 2023
I’m going to automate our process by Excel VBA macro.
When I call Jira REST API https://insight.fsoft.com.vn/jira9/rest/api/2/myself from VBA macro, it received error 403.
The response message below doesn’t help me to determine the reason of the error.
Is there any solution to resolve this error?
[HTTP response]
<html>
<head>
<title>Forbidden (403)</title>
<!--[if IE]><![endif]-->
<script type="text/javascript">
(function() {
var contextPath = '/jira9';
function printDeprecatedMsg() {
if (console && console.warn) {
console.warn('DEPRECATED JS - contextPath global variable has been deprecated since 7.4.0. Use `wrm/context-path` module instead.');
Object.defineProperty(window, 'contextPath', {
get: function() {
printDeprecatedMsg();
return contextPath;
set: function(value) {
contextPath = value;
</script>
<script data-wrm-key="com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-perf-observer,jira.webresources:resource-phase-checkpoint-init" data-wrm-batch-type="resource" data-initially-rendered>
window.__resourcePhaseCheckpointResolvers={resolveDeferPhaseCheckpoint:null,resolveInteractionPhaseCheckpoint:null},window.performance&&window.performance.mark&&(window.DeferScripts||(window.DeferScripts={}),window.DeferScripts.totalClicks=0,window.DeferScripts.totalKeydowns=0,window.DeferScripts.clickListener=function(){"use strict";window.DeferScripts.totalClicks+=1},window.addEventListener("click",window.DeferScripts.clickListener),window.DeferScripts.keydownListener=function(){"use strict";window.DeferScripts.totalKeydowns+=1},window.addEventListener("keydown",window.DeferScripts.keydownListener)),window.resourcePhaseCheckpoint=Object.freeze({defer:new Promise(function(e){"use strict";window.__resourcePhaseCheckpointResolvers.resolveDeferPhaseCheckpoint=e}),interaction:new Promise(function(e){"use strict";window.__resourcePhaseCheckpointResolvers.resolveInteractionPhaseCheckpoint=e})}),Object.freeze(window.__resourcePhaseCheckpointResolvers);
!function(){"use strict";if("PerformanceObserver"in window){const e=[];window.__observedResources=e;const r=e=>"script"===e?"script":"css";new PerformanceObserver((n=>{n.getEntries().filter((({initiatorType:e,name:r})=>{const n="script"===e||((e,r)=>"link"===e&&"css"===new URL(r).pathname.split(".").pop())(e,r),i=new URL(location.href).origin===new URL(r).origin;return n&&i})).forEach((({name:n,transferSize:i,encodedBodySize:s,initiatorType:o})=>{e.push([i,s,n,r(o)])}))})).observe({type:"resource"})}}();
</script>
<script>
window.WRM=window.WRM||{};window.WRM._unparsedData=window.WRM._unparsedData||{};window.WRM._unparsedErrors=window.WRM._unparsedErrors||{};
WRM._unparsedData["com.atlassian.jira.ext.calendar:tipDataProvider.tip"]="{\"suppressTip\":false}";
WRM._unparsedData["jira.core:default-comment-security-level-data.DefaultCommentSecurityLevelHelpLink"]="{\"extraClasses\":\"default-comment-level-help\",\"title\":\"Commenting on an Issue\",\"url\":\"https://docs.atlassian.com/jira/jcore-docs-091/Editing+and+collaborating+on+issues#Editingandcollaboratingonissues-restrictacomment\",\"isLocal\":false}";
WRM._unparsedData["jira.core:feature-flags-data.feature-flag-data"]="{\"enabled-feature-keys\":[\"com.atlassian.jira.agile.darkfeature.editable.detailsview\",\"nps.survey.inline.dialog\",\"com.atlassian.jira.agile.darkfeature.edit.closed.sprint.enabled\",\"jira.plugin.devstatus.phasetwo\",\"jira.frother.reporter.field\",\"atlassian.rest.xsrf.legacy.enabled\",\"jira.issue.status.lozenge\",\"com.atlassian.jira.projects.issuenavigator\",\"com.atlassian.jira.config.PDL\",\"jira.plugin.devstatus.phasetwo.enabled\",\"atlassian.aui.raphael.disabled\",\"app-switcher.new\",\"frother.assignee.field\",\"com.atlassian.jira.projects.ProjectCentricNavigation.Switch\",\"jira.onboarding.cyoa\",\"com.atlassian.jira.agile.darkfeature.kanplan.enabled\",\"com.atlassian.jira.config.ProjectConfig.MENU\",\"com.atlassian.jira.projects.sidebar.DEFER_RESOURCES\",\"com.atlassian.jira.agile.darkfeature.kanplan.epics.and.versions.enabled\",\"com.atlassian.jira.agile.darkfeature.sprint.goal.enabled\",\"jira.zdu.admin-updates-ui\",\"jira.
zdu.jmx-monitoring\",\"mail.batching.enabled\",\"sd.new.settings.sidebar.location.disabled\",\"jira.zdu.cluster-upgrade-state\",\"com.atlassian.jira.email.templates.readFromJiraHome\",\"com.atlassian.jira.agile.darkfeature.splitissue\",\"com.atlassian.profiling.ita.metrics.deny\",\"com.atlassian.jira.config.CoreFeatures.LICENSE_ROLES_ENABLED\",\"jira.export.csv.enabled\"],\"feature-flag-states\":{\"com.atlassian.jira.use.same.site.none.for.xsrf.token.cookie\":true,\"com.atlassian.jira.agile.darkfeature.handle.ug.usernames\":true,\"com.atlassian.jira.security.endpoint.non.admin.access.screens\":false,\"com.atlassian.jira.mailHandlerImapMessageQueryLegacy\":false,\"com.atlassian.diagnostics.scheduler.monitor\":true,\"com.atlassian.jira.webhookEventsAsyncProcessing\":false,\"com.atlassian.jira.serAllowShareWithNonMember\":true,\"com.atlassian.jira.diagnostics.perflog\":true,\"com.atlassian.jira.dbr\":true,\"com.atlassian.jira.bc.user.search.MeasuringUserPickerSearchService\":false,\"com.atlassian.jira.agile.dar
kfeature.legacy.epic.picker\":false,\"com.atlassian.jira.issuetable.move.links.hidden\":true,\"com.atlassian.jira.agile.darkfeature.unlink.sprints.on.issue.move\":true,\"jira.renderer.consider.variable.format\":true,\"jira.no.frother.multiuserpicker.field\":false,\"com.atlassian.jira.plugin.issuenavigator.jql.autocomplete.eagerlyLoaded\":false,\"com.atlassian.jira.user.dbIdBasedKeyGenerationStrategy\":true,\"com.atlassian.portfolio.dcBundling\":true,\"com.atlassian.jira.sharedEntityEditRights\":true,\"com.atlassian.jira.security.endpoint.anonymous.access.resolution\":false,\"com.atlassian.jira.agile.darkfeature.sprint.goal\":true,\"com.atlassian.jira.thumbnailsDeferredGeneration\":true,\"jira.cluster.monitoring.show.offline.nodes\":true,\"com.atlassian.jira.commentReactions\":true,\"data.pipeline.feature.jira.issue.links.export\":true,\"com.atlassian.jira.custom.csv.escaper\":true,\"com.atlassian.jira.fixedCommentDeletionNotifications\":true,\"com.atlassian.jira.allThumbnailsDeferred\":false,\"com.atlassian.
jira.plugin.issuenavigator.filtersUxImprovment\":true,\"com.atlassian.jira.agile.darkfeature.kanplan.epics.and.versions\":true,\"com.atlassian.jira.jsd.mobile\":true,\"jira.customfields.cleanup.identification\":false,\"data.pipeline.feature.jira.all.exportable.custom.fields\":true,\"com.atlassian.jira.defaultValuesForSystemFields\":true,\"jira.dc.cleanup.cluser.tasks\":true,\"jira.customfields.bulk.delete\":false,\"mail.batching.override.core\":true,\"com.atlassian.jira.issues.archiving.filters\":false,\"jira.users.and.roles.page.in.react\":true,\"jira.security.csp.sandbox\":true,\"com.atlassian.jira.agile.darkfeature.synced.sprints\":false,\"com.atlassian.jira.agile.darkfeature.velocity.chart.ui\":true,\"com.atlassian.jira.returnDefaultAvatarsForBrokenAvatars\":true,\"com.atlassian.jira.agile.darkfeature.sprint.auto.management\":false,\"jira.jql.suggestrecentfields\":false,\"com.atlassian.jira.gdpr.rtbf\":true,\"com.atlassian.jira.security.xsrf.session.token\":true,\"com.atlassian.jira.security.project.admi
n.revoke.with.application.access\":true,\"com.atlassian.jira.agile.darkfeature.optimistic.transitions\":true,\"com.atlassian.jiranomenclature\":true,\"com.atlassian.jira.security.endpoint.non.admin.access.avatar.system\":false,\"com.atlassian.jira.agile.darkfeature.kanplan\":true,\"com.atlassian.jira.agile.darkfeature.boards.find.on.board\":true,\"com.atlassian.diagnostics.http.monitor\":true,\"com.atlassian.jira.agile.darkfeature.future.sprint.dates\":true,\"jira.customfields.paginated.ui\":true,\"com.atlassian.jira.filtersAndDashboardsShareableWithAllGroupsAndRoles\":true,\"com.atlassian.jira.in.product.diagnostics\":false,\"com.atlassian.jira.agile.darkfeature.edit.closed.sprint\":true,\"jira.create.linked.issue\":true,\"jira.sal.host.connect.accessor.existing.transaction.will.create.transactions\":true,\"com.atlassian.jira.advanced.audit.log\":true,\"jira.quick.search\":true,\"external.links.new.window\":true,\"jira.jql.smartautoselectfirst\":false,\"jira.jql.membersof.ignoreGlobalPermissionsForAnonymous
\":false,\"data.pipeline.feature.jira.issue.history.export\":true,\"jira.webactions.request.method.recognition\":true,\"jira.richeditor.bidi.warning\":true,\"com.atlassian.jira.security.endpoint.non.browse.projects.access.fields\":false,\"atlassian.cdn.static.assets\":true,\"com.atlassian.jira.lazyload.activity.tabs\":true,\"mail.batching\":true,\"com.atlassian.jira.safeguards\":true,\"com.atlassian.jira.xml.deserializerAllowlist\":true,\"com.atlassian.jira.privateEntitiesEditable\":true,\"com.atlassian.jira.security.endpoint.anonymous.access.priority\":false,\"jira.priorities.per.project.edit.default\":false,\"com.atlassian.jira.agile.darkfeature.issues.in.epic.details.view\":true,\"com.atlassian.jira.plugin.issuenavigator.anonymousPreventCfData\":false,\"jira.priorities.per.project.jsd\":true,\"com.atlassian.jira.safeguards.email.notifications\":true,\"com.atlassian.jira.agile.darkfeature.rapid.boards.bands\":true,\"com.atlassian.jira.agile.darkfeature.flexible.boards\":true,\"com.atlassian.jira.agile.dark
feature.sprint.picker.allsprints.suggestion\":true,\"com.atlassian.jira.agile.darkfeature.epic.validate.visibility\":true,\"data.pipeline.feature.jira.issue.rank.export\":true,\"data.pipeline.feature.jira.jsm.approvals.export\":true,\"jira.dc.lock.leasing\":true,\"com.atlassian.jira.accessibility.personal.settings\":true,\"mail.batching.create.section.cf\":true,\"com.atlassian.jira.send.email.notifications.to.user.without.application.access\":false,\"com.atlassian.jira.security.endpoint.non.browse.projects.access.autocompletedata\":false,\"com.atlassian.mail.server.managers.hostname.verification\":true,\"com.atlassian.diagnostics.monitors\":true,\"com.atlassian.jira.upgrade.startup.fix.index\":true,\"com.atlassian.jira.security.endpoint.anonymous.access.projectCategory\":false,\"jira.redirect.anonymous.404.errors\":true,\"com.atlassian.jira.issuetable.draggable\":true,\"data.pipeline.feature.jira.jsm.canned.responses.export\":true,\"com.atlassian.diagnostics.operating.system.monitor\":false,\"com.atlassian.j
ira.attachments.generate.unique.suffix\":true,\"com.atlassian.jira.agile.darkfeature.kanban.hide.old.done.issues\":true,\"jira.version.based.node.reindex.service\":true,\"com.atlassian.jira.agile.darkfeature.backlog.showmore\":true,\"com.atlassian.diagnostics.database.monitor\":true,\"com.atlassian.jira.agile.darkfeature.sprint.plan\":false,\"com.atlassian.diagnostics.garbage.collection.monitor\":true,\"com.atlassian.jira.security.endpoint.anonymous.access.issueLinkType\":false,\"jira.jql.membersof.ignoreGlobalPermissionsForLoggedUsers\":false,\"com.atlassian.jira.safeguards.work.in.progress\":false,\"com.atlassian.jira.security.LegacyJiraTypeResolver.WARN_ONLY\":false,\"data.pipeline.feature.jira.schema.version.2\":true,\"com.atlassian.jira.agile.darkfeature.burnupchart\":true,\"com.atlassian.jira.issues.archiving.browse\":true,\"com.atlassian.jira.agile.darkfeature.velocity.sprint.picker\":false,\"jira.instrumentation.laas\":false,\"com.atlassian.jira.security.ChartUtils.browse.projects.permission.check\":
false,\"data.pipeline.feature.jira.jsm.kb.stats.events.export\":true,\"mail.batching.user.notification\":true,\"com.atlassian.diagnostics.jql.monitor\":true,\"com.atlassian.portfolio.permission.check.for.permissions\":true,\"com.atlassian.jira.agile.darkfeature.dataonpageload\":true,\"jira.webactions.request.method.dependent.xsrf.checks\":true,\"data.pipeline.feature.jira.archived.issue.export\":false,\"com.atlassian.jira.projects.per.project.permission.query\":true,\"com.atlassian.jira.issues.archiving\":true,\"jira.priorities.per.project\":true,\"index.use.snappy\":true}}";
WRM._unparsedData["jira.core:terminology-data.terminology"]="{\"terminologyEntries\":[{\"originalName\":\"sprint\",\"originalNamePlural\":\"sprints\",\"newName\":\"sprint\",\"newNamePlural\":\"sprints\",\"isDefault\":true},{\"originalName\":\"epic\",\"originalNamePlural\":\"epics\",\"newName\":\"epic\",\"newNamePlural\":\"epics\",\"isDefault\":true}],\"isTerminologyActive\":false}";
WRM._unparsedData["com.atlassian.plugins.helptips.jira-help-tips:help-tip-manager.JiraHelpTipData"]="{\"anonymous\":true}";
WRM._unparsedData["jira.core:avatar-picker-data.data"]="{}";
WRM._unparsedData["com.atlassian.analytics.analytics-client:programmatic-analytics-init.programmatic-analytics-data-provider"]="false";
WRM._unparsedData["com.atlassian.plugins.atlassian-plugins-webresource-plugin:context-path.context-path"]="\"/jira9\"";
WRM._unparsedData["com.atlassian.analytics.analytics-client:policy-update-init.policy-update-data-provider"]="false";
WRM._unparsedData["com.atlassian.jira.jira-header-plugin:newsletter-signup-tip-init.newsletterSignup"]="{\"signupDescription\":\"Get updates, inspiration and best practices from the team behind Jira.\",\"formUrl\":\"https://www.atlassian.com/apis/exact-target/{0}/subscribe?mailingListId=1401671\",\"signupTitle\":\"Sign up!\",\"signupId\":\"newsletter-signup-tip\",\"showNewsletterTip\":false}";
WRM._unparsedData["jira.core:dateFormatProvider.allFormats"]="{\"dateFormats\":{\"meridiem\":[\"AM\",\"PM\"],\"eras\":[\"BC\",\"AD\"],\"months\":[\"January\",\"February\",\"March\",\"April\",\"May\",\"June\",\"July\",\"August\",\"September\",\"October\",\"November\",\"December\"],\"monthsShort\":[\"Jan\",\"Feb\",\"Mar\",\"Apr\",\"May\",\"Jun\",\"Jul\",\"Aug\",\"Sep\",\"Oct\",\"Nov\",\"Dec\"],\"weekdaysShort\":[\"Sun\",\"Mon\",\"Tue\",\"Wed\",\"Thu\",\"Fri\",\"Sat\"],\"weekdays\":[\"Sunday\",\"Monday\",\"Tuesday\",\"Wednesday\",\"Thursday\",\"Friday\",\"Saturday\"]},\"lookAndFeelFormats\":{\"relativize\":\"true\",\"time\":\"h:mm a\",\"day\":\"EEEE h:mm a\",\"dmy\":\"dd/MMM/yy\",\"complete\":\"dd/MMM/yy h:mm a\"}}";
WRM._unparsedData["com.atlassian.jira.jira-header-plugin:dismissedFlags.flags"]="{\"dismissed\":[]}";
WRM._unparsedData["com.atlassian.jira.project-templates-plugin:project-templates-plugin-resources.ptAnalyticsData"]="{\"instanceCreatedDate\":\"2020-09-10\"}";
WRM._unparsedData["jira.core:user-message-flags-data.adminLockout"]="{}";
if(window.WRM._dataArrived)window.WRM._dataArrived();</script>
<link rel="stylesheet" href="/jira9/s/84dc1b7478b524b4c7fecfe0053605b9-CDN/nrowl2/901000/xqb923/6e132fee466368cec3dd5e954716694c/_/download/contextbatch/css/_super,-com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-perf-observer,-jira.webresources:resource-phase-checkpoint-init/batch.css" data-wrm-key="_super,-com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-perf-observer,-jira.webresources:resource-phase-checkpoint-init" data-wrm-batch-type="context" media="all">
<link rel="stylesheet" href="/jira9/s/92125fa67dbd41ada4a45841ef1a1eb4-CDN/nrowl2/901000/xqb923/2459d3b795fdee1a9a8b8151ac8ab933/_/download/contextbatch/css/atl.general,atl.global,jira.global,-_super/batch.css?agile_global_admin_condition=true&amp;jag=true" data-wrm-key="atl.general,atl.global,jira.global,-_super" data-wrm-batch-type="context" media="all">
<link rel="stylesheet" href="/jira9/s/d7bd16f437765261ea5883a7dfe5c454-CDN/nrowl2/901000/xqb923/d7b4ed29a8b5d478d7b52b5720c32b9d/_/download/contextbatch/css/jira.general,-_super/batch.css" data-wrm-key="jira.general,-_super" data-wrm-batch-type="context" media="all">
<link rel="stylesheet" href="/jira9/s/e6166eb15167a9dac199586808d9d182-CDN/nrowl2/901000/xqb923/fd5abaa34f958a054548176070b5db63/_/download/contextbatch/css/jira.global.look-and-feel,-_super/batch.css" data-wrm-key="jira.global.look-and-feel,-_super" data-wrm-batch-type="context" media="all">
<script src="/jira9/s/d5252e282195e674839bf1a31e29faa9-CDN/nrowl2/901000/xqb923/6e132fee466368cec3dd5e954716694c/_/download/contextbatch/js/_super,-com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-perf-observer,-jira.webresources:resource-phase-checkpoint-init/batch.js?locale=en-US" data-wrm-key="_super,-com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-perf-observer,-jira.webresources:resource-phase-checkpoint-init" data-wrm-batch-type="context" data-initially-rendered></script>
<script src="/jira9/s/d3dbe151e375eb0946f3bfa913a5fbab-CDN/nrowl2/901000/xqb923/2459d3b795fdee1a9a8b8151ac8ab933/_/download/contextbatch/js/atl.general,atl.global,jira.global,-_super/batch.js?agile_global_admin_condition=true&amp;jag=true&amp;locale=en-US" data-wrm-key="atl.general,atl.global,jira.global,-_super" data-wrm-batch-type="context" data-initially-rendered></script>
<script src="/jira9/s/d41d8cd98f00b204e9800998ecf8427e-CDN/nrowl2/901000/xqb923/d7b4ed29a8b5d478d7b52b5720c32b9d/_/download/contextbatch/js/jira.general,-_super/batch.js" data-wrm-key="jira.general,-_super" data-wrm-batch-type="context" data-initially-rendered></script>
<script type="module">WRM.requireLazily(["wr!com.atlassian.plugins.atlassian-plugins-webresource-rest:data-collector-async"])</script>
<meta name="application-name" content="JIRA" data-name="jira" data-version="9.1.0">
</head>
<body id="jira" class="aui-layout aui-style-default page-type-message " data-version="9.1.0" >
<!-- HTTPError403 -->
<div class="aui-page-panel" ><div class="aui-page-panel-inner">
<main role="main" id="main" class="aui-page-panel-content" >
<div class="aui-page-header" ><div class="aui-page-header-inner">
<div class="aui-page-header-main" >
<h1>Forbidden (403)</h1>
</div>
</div></div>
<div class="aui-message aui-message-warning warning">
<p>Encountered a <code>&quot;403 - Forbidden&quot;</code> error while loading this page.</p>
<p>Basic Authentication Failure - Reason : AUTHENTICATION_DENIED</p>
<p><a href="/jira9/secure/MyJiraHome.jspa">Go to Jira home</a></p>
</div>
</main>
</div></div>
<script type="text/javascript"> var _paq = _paq || []; _paq.push(["trackPageView"]); _paq.push(["enableLinkTracking"]); (function() { var u="//analytics.fsoft.com.vn/"; _paq.push(["setTrackerUrl", u+"piwik.php"]); _paq.push(["setSiteId", 182]); var d=document, g=d.createElement("script"), s=d.getElementsByTagName("script")[0]; g.type="text/javascript"; g.async=true; g.defer=true; g.src=u+"piwik.js"; s.parentNode.insertBefore(g,s); })();</script><noscript><p><img src="//analytics.fsoft.com.vn/piwik.php?idsite=182" style="border:0;" alt="" /></p></noscript></body>
</html>
Radek Dostál
June 1, 2023 edited
So,
https://letmegooglethat.com/?q=http+error+403
The response message is as clear as it could be, it even includes the error message (with the reason behind 403) in the response.
Since the bleeding hearts would call me mean, this is what're missing: https://developer.atlassian.com/server/jira/platform/basic-authentication
Kobayashi_Masanao
June 1, 2023
Solved issue,
For authorizetion header, encoded username:password works, not encoded username:personal-access-token.
Thank you!!
