Jira REST API for configuring dashboard gadget
EddieCM_Chuang July 16, 2022
My goal is to create dashboard gadgets automatically and programatically. I tried to create dashboard gadget, filter results, using jira rest api. However, there isn't any parameters to set 'saved filter', 'Number of results' or 'Columns to display' for gadget in api ('add gadget to dashboard', 'update gadget to dashboard'). The only thing I can do with api is create an empty gadget.
How can I configure gadgets using api? If it isn't possible, any alternative solution or workaround?
Fabio Racobaldo _Catworkx_
Hi @EddieCM_Chuang ,
welcome to the Atlassian community!
You should use the following rest api https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-dashboards/#api-rest-api-3-dashboard-dashboardid-items-itemid-properties-propertykey-put in order to setup a gadget on a dashboard using api.
Hope this helps,
Fabio
Thanks a lot! I will study the dashboard item.
I'm curious about why Jira provides the rest api to add/update gadgets, but not to configure gadgets.
Arun January 4, 2024 edited
Hi @Fabio Racobaldo _Herzum_
import
ForgeUI, { render, Fragment, Macro, Text, useState } from "@forge/ui";
import api, { route } from "@forge/api";
const getDashoardDetails = async () => {
  var bodyData = `{
    "description": "A dashboard to help auditors identify sample of issues to check.",
    "editPermissions": [],
    "name": "Auditors dashboard",
    "sharePermissions": [
        "type": "global"
  const response = await api.asUser().requestJira(route`/rest/api/3/dashboard`, {
    method: 'POST',
    headers: {
      'Accept': 'application/json',
      'Content-Type': 'application/json'
    body: bodyData
  console.log(`Response: ${response.status} ${response.statusText}`);
  console.log(await response.json());
const App = () => {
  const dashboards = useState(async () => await getDashoardDetails());
  console.log('--> dashboardDetails', dashboards);
  return (
    <Fragment>
      <Text>Hello world!</Text>
    </Fragment>
export const run = render(
  <Macro
    app={<App />}
my forge app code is here am trying to create a dashboard on forge app here am facing some issues on server after deployed on server it returning an null value on the logs
[ null, "[Function]" ]
Thanks for @Fabio Racobaldo _Catworkx_ suggestion.
My python implementation using jira api `set dashboard item properties`.
payload = json.dumps({
    "filterId": "10711",
    "num": "50",
    "columnNames": "issuetype|summary|issuekey",
    "refresh": "true",
    "isConfigured": "true"
res = requests.request(
    "PUT",
    f"{HOST}/rest/api/3/dashboard/{dashboard_id}/items/{item_id}/properties/config",
    headers={
        "Accept": "application/json",
        "Content-Type": "application/json"
    data=payload,
    auth=HTTPBasicAuth(EMAIL, TOKEN)
you're welcome @EddieCM_Chuang
