Jira Rest API Single Sign On Authentication
Anirudha Karwa June 13, 2014
I am trying to create/search an issue through rest api (in C#). The intranet we are using have a single sign on functionality. So when I surf through browser, it is smart enough to fetch the latest session id and authenticate to the SSO login. I am stuck with the SSO login via api. Any idea on how to overcome or bypass the SSO login through api code?
Thanks in advance.
Ed Letifov _TechTime - New Zealand_
June 13, 2014
Normally you would configure SSO for JIRA to ignore REST URLs - this would be somewhere in the config parameters of our SSO filter
Anirudha Karwa June 16, 2014
Hi Ed,
Thank you for your reply. I have a question. What do you mean by "our SSO filter". My thinking is, in my intranet setting, I have to add ignore exception for JIRA REST url. SSO is not related to JIRA, right?
