Jira Rest Api Basic Auth - PowerShell - Building with secure strings
Shop Rogers March 27, 2018
I've been trying to build out basic auth using powershell user persistent variables where I store the password as a secure string. This is what I have so far:
$PlainPassword = "atestpassword"
$SecurePassword = $PlainPassword | ConvertTo-SecureString -AsPlainText -Force | ConvertFrom-SecureString
[Environment]::SetEnvironmentVariable('JiraCreds', $SecurePassword, "User")
$cred = New-Object pscredential "TestUser", (ConvertTo-SecureString $env:JiraCreds)
$newPassword = $cred.Password
#NOTE: This returns 403 forbidden when making rest api calls with the basic auth token
$header = @{"Authorization" = "Basic "+[System.Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes("TestUser:$(ConvertFrom-SecureString $newPassword)"))}
#NOTE: Using this returns a 401 unauthorized when using this for get/post rest api calls with the basic auth token
$header = @{Authorization = 'Basic ' + [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes("TestUser:$(ConvertFrom-SecureString $newPassword)"))}
The issue I’ve been running into all along is that I’m not sure how to adjust the code to properly translate the securestring in a way that builds the basic auth token correctly. One thing I noticed is that the basic auth tokens using the two methods above are much longer than what they should be compared to the following method:
$header = @{Authorization = 'Basic ' + [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes("TestUser:atestpassword "))}
I’ve even tested the basic auth tokens in postman and they are failing there too.
NOTE: I have confirmed the json and the jira endpoint as well as method are working by testing with a basic auth method that does work in PowerShell.
Any help with this would be greatly appreciated.
Shop Rogers April 3, 2018
this isn't possible since basic auth requires the password in plain text. OAuth token would be a possible resolution to this issue.
Learn more
