Jira Rest Java Client JSONObject[type] not found
Erik Macias November 13, 2017
(Created this discussion earlier, but was not posted so recreating. Apologies if duplicated)
Hi, I am trying to setup the Hygieia dashboard and while setting up the jira-collector (which has jira-rest-java-client-core v3.0.0 as a dependency) I came across the following error:
2017-11-08 10:34:59,998 INFO c.c.d.collector.CollectorTask - Running Collector: Jira
2017-11-08 10:35:00,007 INFO c.c.d.collector.CollectorTask - -----------------------------------
2017-11-08 10:35:00,007 INFO c.c.d.collector.CollectorTask - https://my.jira.com/
2017-11-08 10:35:00,009 DEBUG c.c.d.client.team.TeamDataClientImpl - Constructing data collection for the feature widget, team-level data...
2017-11-08 10:35:00,024 INFO c.c.d.collector.CollectorTask - Team Data 0 0s
2017-11-08 10:35:00,025 DEBUG c.c.d.c.p.ProjectDataClientImpl - Constructing data collection for the feature widget, project-level data...
2017-11-08 10:35:02,673 DEBUG c.c.d.c.p.ProjectDataClientImpl - Size of paged Jira response: 947
2017-11-08 10:35:04,434 INFO c.c.d.collector.CollectorTask - Project Data 947 4s
2017-11-08 10:35:04,437 DEBUG c.c.d.c.story.StoryDataClientImpl - Constructing data collection for the feature widget, story-level data...
2017-11-08 10:35:05,430 DEBUG c.c.d.c.story.StoryDataClientImpl - Obtaining story information starting at index 0...
2017-11-08 10:35:13,707 ERROR c.c.d.client.DefaultJiraClient - No result was available from Jira unexpectedly - defaulting to blank response. The reason for this fault is the following:RestClientException{statusCode=Optional.absent(), errorCollections=[]}
2017-11-08 10:35:13,723 DEBUG c.c.d.client.DefaultJiraClient - Exception
com.atlassian.jira.rest.client.api.RestClientException: org.codehaus.jettison.json.JSONException: JSONObject["type"] not found.
at com.atlassian.jira.rest.client.internal.async.DelegatingPromise.claim(DelegatingPromise.java:47) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.capitalone.dashboard.client.DefaultJiraClient.getIssues(DefaultJiraClient.java:101) ~[jira-feature-collector.jar!/:2.0.5-SNAPSHOT]
at com.capitalone.dashboard.client.story.StoryDataClientImpl.updateStoryInformation(StoryDataClientImpl.java:162) [jira-feature-collector.jar!/:2.0.5-SNAPSHOT]
at com.capitalone.dashboard.collector.FeatureCollectorTask.collect(FeatureCollectorTask.java:119) [jira-feature-collector.jar!/:2.0.5-SNAPSHOT]
at com.capitalone.dashboard.collector.FeatureCollectorTask.collect(FeatureCollectorTask.java:28) [jira-feature-collector.jar!/:2.0.5-SNAPSHOT]
at com.capitalone.dashboard.collector.CollectorTask.run(CollectorTask.java:63) [core-2.0.5-SNAPSHOT.jar!/:2.0.5-SNAPSHOT]
at org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54) [spring-context-4.2.5.RELEASE.jar!/:4.2.5.RELEASE]
at org.springframework.scheduling.concurrent.ReschedulingRunnable.run(ReschedulingRunnable.java:81) [spring-context-4.2.5.RELEASE.jar!/:4.2.5.RELEASE]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [na:1.8.0_131]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [na:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [na:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [na:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [na:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [na:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [na:1.8.0_131]
Caused by: com.atlassian.jira.rest.client.api.RestClientException: org.codehaus.jettison.json.JSONException: JSONObject["type"] not found.
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:188) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:182) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.httpclient.api.ResponsePromiseMapFunction.apply(ResponsePromiseMapFunction.java:62) ~[atlassian-httpclient-api-0.13.2.jar!/:na]
at com.atlassian.httpclient.api.ResponsePromiseMapFunction.apply(ResponsePromiseMapFunction.java:12) ~[atlassian-httpclient-api-0.13.2.jar!/:na]
at com.atlassian.util.concurrent.Promises$Of$3.apply(Promises.java:285) ~[atlassian-util-concurrent-2.4.0-M9.jar!/:na]
at com.atlassian.util.concurrent.Promises$2.onSuccess(Promises.java:162) ~[atlassian-util-concurrent-2.4.0-M9.jar!/:na]
at com.google.common.util.concurrent.Futures$4.run(Futures.java:1154) ~[guava-14.0.jar!/:na]
at com.google.common.util.concurrent.MoreExecutors$SameThreadExecutorService.execute(MoreExecutors.java:293) ~[guava-14.0.jar!/:na]
at com.google.common.util.concurrent.ExecutionList$RunnableExecutorPair.execute(ExecutionList.java:150) ~[guava-14.0.jar!/:na]
at com.google.common.util.concurrent.ExecutionList.execute(ExecutionList.java:135) ~[guava-14.0.jar!/:na]
at com.google.common.util.concurrent.AbstractFuture.set(AbstractFuture.java:185) ~[guava-14.0.jar!/:na]
at com.google.common.util.concurrent.SettableFuture.set(SettableFuture.java:53) ~[guava-14.0.jar!/:na]
at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$1$1.run(SettableFuturePromiseHttpPromiseAsyncClient.java:46) ~[atlassian-httpclient-apache-httpcomponents-0.13.2.jar!/:na]
at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$ThreadLocalDelegateRunnable$1.run(SettableFuturePromiseHttpPromiseAsyncClient.java:197) ~[atlassian-httpclient-apache-httpcomponents-0.13.2.jar!/:na]
at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient.runInContext(SettableFuturePromiseHttpPromiseAsyncClient.java:90) ~[atlassian-httpclient-apache-httpcomponents-0.13.2.jar!/:na]
at com.atlassian.httpclient.apache.httpcomponents.SettableFuturePromiseHttpPromiseAsyncClient$ThreadLocalDelegateRunnable.run(SettableFuturePromiseHttpPromiseAsyncClient.java:192) ~[atlassian-httpclient-apache-httpcomponents-0.13.2.jar!/:na]
... 3 common frames omitted
Caused by: org.codehaus.jettison.json.JSONException: JSONObject["type"] not found.
at org.codehaus.jettison.json.JSONObject.get(JSONObject.java:360) ~[jettison-1.1.jar!/:1.1]
at org.codehaus.jettison.json.JSONObject.getString(JSONObject.java:487) ~[jettison-1.1.jar!/:1.1]
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parseSchema(IssueJsonParser.java:344) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parseFields(IssueJsonParser.java:309) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parse(IssueJsonParser.java:223) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.IssueJsonParser.parse(IssueJsonParser.java:88) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.GenericJsonArrayParser.parse(GenericJsonArrayParser.java:39) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.SearchResultJsonParser.parse(SearchResultJsonParser.java:40) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.json.SearchResultJsonParser.parse(SearchResultJsonParser.java:27) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$1.handle(AbstractAsynchronousRestClient.java:145) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
at com.atlassian.jira.rest.client.internal.async.AbstractAsynchronousRestClient$3.apply(AbstractAsynchronousRestClient.java:186) ~[jira-rest-java-client-core-3.0.0.jar!/:na]
... 26 common frames omitted
2017-11-08 10:35:13,724 DEBUG c.c.d.c.story.StoryDataClientImpl - Story information query took 8293 ms
2017-11-08 10:35:13,724 INFO c.c.d.c.story.StoryDataClientImpl - Loop i 0 pageSize 0
2017-11-08 10:35:13,724 INFO c.c.d.collector.CollectorTask - Story Data 0 9s
2017-11-08 10:35:13,724 INFO c.c.d.collector.CollectorTask - Finished 13s
It appears that the exception is thrown from:
and that line looks like this:
(line 343) JSONObject fieldDefinition = json.getJSONObject(fieldId);
(line 344) res.put(fieldId, fieldDefinition.getString("type")); <<< res is a map returned by this method
The json object parsed by IssueJsonParser.parseSchema causing the exception looks like:
{"custom":"com.onresolve.jira.groovy.groovyrunner:scripted-field","customId":xxxxx}
which does not contain the field "type".
As IssueJsonParser.parseSchema is a private method only being called by IssueJsonParser.parseFields, and that method is only concerned with fields with type "key":
res.add(new IssueField(key, namesMap.get(key), typesMap.get("key"), value != JSONObject.NULL ? value : null));
should IssueJsonParser.parseSchema check for the "type" field prior to adding to the map, i.e.:
(line 344 becomes)
if (fieldDefinition.has("type")) {
or should 'com.onresolve.jira.groovy.groovyrunner:scripted-field' be required to contain a "type" field?
Currently I am implementing the if-statement, but that requires me to maintain my own version of jrjc which I would rather avoid doing. I am new to Jira and jrjc so I was hoping to start a discussion on whether adding the if-statement is most appropriate or if adding the "type" field is a better option. If the latter, how would one go about adding this field? Any help would be much appreciated, thanks.
Erik Macias July 10, 2018
This issue appears to be stuck in limbo:
https://productsupport.adaptavist.com/browse/SRJIRA-2656
