Jira Search - Type 'Test' is not a valid for your current project selection
pvlakshmikanth
Hi We are using Jira XRay for test management. When I use search issues and select Type Test it show noting and warning says 'type test is not a valid for your current project selection' but we have Test Type as issue in our project configuration and created 1000+, still Test type is not a valid for your current project; Please assist.
pvlakshmikanth
pvlakshmikanth
Hi Sam, please find the error snapshot. We have Test Type in our project and its lists in issue type also but give error.
Sam Hall
December 7, 2020
When searching, do you have a project selected in the 'Project' selector, or is it set to 'All'?
If you can post a screenshot here (with any sensitive info blurred/hidden), it might help members of the community to suggest answers.
Alternatively, you could contact XRay directly for support specific to the add-on: https://xraysupport.xpand-it.com/
pvlakshmikanth
Adding Advance search: project = BS AND issuetype = Test
It's not returning any results.
Jason Christina
December 7, 2020
Are the 1000+ tests you mentioned in the BS project? Also, what returns when you search just on issuetype = Test without a project selected?
pvlakshmikanth
Hi Christina, all the 1000+ test are from BS project only and its lists test type also in issue type in search issue.
Nothing returned if I remove project and select type test
