Jira Server vs. Jira Datacenter plugin compatibility
Wayne Kohler October 12, 2022
In general, can Java plugins developed for Jira Server be used on Jira Datacenter?
Nic Brough -Adaptavist-
October 12, 2022
Very broadly speaking, yes.  Most DC-compatible apps I know of are the same as, or forks of, their older server-based incarnations.
Simple core functionality in server and DC is pretty much the same, so apps that don't have complex needs will simply work.  The most obvious ones are reports - they're simple flat reads of data and don't need to do anything that's affected by server or DC.
There's a nice list of things all DC developers need to think about on top of developing for server (albeit, some of them they should be thinking about for Server anyway) - https://developer.atlassian.com/platform/marketplace/guidelines-for-data-center-app-development/
(p.s. DC apps are always compatible with Server, unless someone found a good reason to code for "hey, work differently if there's only one node in the cluster")
Florian Bonniec
October 12, 2022 edited
Hi @Wayne Kohler
Yes it should work but it's not recommanded. You may face stange behaviours on some app because it's not means to work in a cluster so you often face cache issues.
Please find Atlassian related kb below.
https://confluence.atlassian.com/jirakb/using-non-dc-compatible-apps-in-data-center-instance-969532847.html
Regards
