Jira Solman/SAP integration
Konstantin Gagač June 18, 2019
i need to connect Jira software with Solman.
In web i found some plugin that looks like fit best to us:
https://github.com/SAP/solman-fb-jira-addon
i tried to compile but i get this error on
[ERROR] Failed to execute goal on project jiraintegration: Could not resolve dependencies for project com.sap.mango:jiraintegration:jar:2.1.0: Failure to find jta:jta:jar:1.0.1 in https://maven.atlassian.com/repository/public was cached in the local repository, resolution will not be reattempted until the update interval of atlassian-public has elapsed or updates are forced
Link returns:
  "errors" : [ {
    "status" : 404,
    "message" : "Not Found"
I found another valid repository  link is used now (https://packages.atlassian.com/content/repositories/atlassian-public/), but i didn't found jiraintegration in it or anywhere on web.
Tim Eddelbüttel
June 18, 2019
Hello Konstantin,
due to licensing restrictions, JTA can't be distributed from Atlassian's public Maven repository.
Search here for JTA: https://developer.atlassian.com/server/jira/platform/building-jira-from-source/
You have to download it manually and install it into the local maven repository:
Example:
mvn install:install-file -DgroupId=jta -DartifactId=jta -Dversion=1.0.1 -Dpackaging=jar -Dfile=jta-1_0_1B-classes.jar
 Kind Regards,
Tim
Learn more
