Jira Startup failed
Ashi Gupta
November 2, 2012
I am using linux opensuse12.1 kernel version 3.1.0 and installed jira version 5.1.8 on it. I am running linux server and firstly able to use successfully jira. But when i restarted my server i gor issue with jira mentioned below:
JIRA Startup Failed
You cannot access JIRA at present. Look at the table below to identify the reasons
Description
The following plugins are required by JIRA, but have not been started:
Atlassian JIRA - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
Opensocial Plugin (com.atlassian.gadgets.opensocial)
Gadget Directory Plugin (com.atlassian.gadgets.directory)
Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
Need Help to resolve this as soon as possible.
Septa Cahyadiputra
November 2, 2012
Hi Ashi,
There might be multiple causes of this failed plugin initialization, in order to narrow down the root cause of the issue you would need to review JIRA logs which is located in <JIRA_HOME_Dir>/logs/atlassian-jira.log.
You could also try the following troubleshooting steps and see how it goes:
  1. Shutdown JIRA
  2. Remove the following files:
    $JIRA_HOME/plugins/.bundled_plugins
    $JIRA_HOME/plugins/.osgi_plugins
    These are temporary files and folders and will be recreated when JIRA starts.
  3. Ensure that your JVM_MINIMUM and MAXIMUM is at least 1024
  4. Re-start JIRA
Hope it helps.
Septa Cahyadiputra
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
