Jira Story Maps in Safari 14 stutters
I Hoevenaar
September 23, 2020 edited
scrolling on the screen of the Story Map results is stuttering of the screen. both when navigating horizontally and vertically. This has started since safari 14 was installed. No problem with Brave of Chrome on same laptop.
anyone having the same problems or many solution?
Jared Kells
September 28, 2020
Hey,
I'm from Easy Agile, we make one of the Story Mapping add-ons on the marketplace. Is the stuttering happening in our add-on, or is it a different Story Map?
I've just tested Easy Agile User Story Maps on Safari 14 and Jira 8.12 and it seems to be working ok with no stutter.
If the issue is with our add-on would you mind capturing a video of the behaviour and sending it through to support@easyagile.com?
Jared Kells
I Hoevenaar
September 28, 2020
I do not know if we use you add-on but send you the video capture of it. THX
Jack Brickey
I will report this to Atlassian support. I’ve noticed a few oddities with Safari 14 myself. I fully suspect issues will get resolved by Apple or Atlassian in the coming weeks.
Pinchus Gelbman September 23, 2020 edited
I'm also experiencing this running Jira Server 8.2.3 after updating Safari on my Mac to 14.0 and it's really annoying that after each and every click you need to refresh the page.
Another strange behavior I've realized is that when you get into an issue and hit the m shortcut key in order to enter a new comment it wouldn't set focus into the new comment which is extremely annoying and only got affected after upgrading my Safari to Version 14.0
