I have a structure with an Insert generator inserting "Feature" issues. Then I have an "Extend" generator that adds linked issues, i.e. child Stories. These child Stories started off with a single label, e.g. "Modules", and I was able to count the number of issues with that particular label and get percentage of "in progress" issues using the following formula:
IF ( issuetype = "Feature" ;
IF ( issuelinks.FILTER($.type = 'Stories' AND $.destination.labels = "Modules").SIZE() > 0 ;
WITH storyProgress = issuelinks.FILTER($.type = 'Stories' AND $.destination.labels = "Modules" AND ($.destination.status = "Implementation In Progress" OR $.destination.status = "Implementation Review" OR $.destination.status = "Closed" ) ).SIZE() / issuelinks.FILTER($.type = 'Stories' AND $.destination.labels = "Modules" ).SIZE() * 100 :
storyProgress
Now, as soon as the stories have more than one labels, the code:
no longer works, since the labels value returns ALL the labels for any given story.
Any suggestion on a way to count if the labels value "contains" a particular label when the labels value contains multiple labels?
Hello @Tommy Heyser ,
I believe the CONTAINS() function should work for you in this case.
You should be able to string it together with what you already have, like this:
$.destination.labels.CONTAINS("Modules")
Please let me know if it helps!
Best,
David
