Jira Structure - JQL to display closed issues when their
Rafael Tognolo
I'm trying to create a Structure with 2 different sections.
1 - This section should show all issues that are currently open, or belong to an Epic or Task that is not fully closed (at least one child ticket is still open)
2 - This section should show only closed issues or Epics and Tasks that are fully closed (all child tickets are also closed)
Are you able to assist with this JQL?
Thank you
David Niro
Hello @Rafael Tognolo ,
David from ALM Works here.
We should be able to figure something out.  To make sure we're on the same page to start, could you describe the hierarchy you are trying to build?  In other words, do you want
Epics
  Tasks
    Sub-Tasks
  Stories
Or something flat, like
Epics
Tasks
Stories
Also, could an Epic or Task be closed but still have open "children"?  could an Epic or Task still be open even if all its "children" are closed?
Looking forward to your response.
Best Regards,
David
Rafael Tognolo
Hello @David Niro
Thanks for the swift response.
The hierarchy is like this:
Epic
    Task
        Sub-task
And the answer is Yes to both: Also, could an Epic or Task be closed but still have open "children"?  could an Epic or Task still be open even if all its "children" are closed?
Even though this is not ideal, sometimes I come across these cases. Is there a way to prevent it?
For example, if all children's tickets are closed, then the epic is automatically closed. Or if one of children's tasks are open, the Epic cannot be closed?
Like Dave Rosenlund _Trundl_ likes this
David Niro
You are very welcome!  Thank you for the additional information!
I have an idea for this, but it is going to depend on which hosting method you are using (Cloud or On Prem).
I noticed you tagged "unknown-hosting-type".  There's a very quick way to determine this.
When you are in Structure, do you see a button for "Automation" or "Show Generators"?  If you see the former, you are "on prem" and the latter would indicate you are "cloud".
What I have in mind will work on prem, but won't yet (we're working on it) be available for cloud.
Best,
David
Like Rafael Tognolo likes this
Rafael Tognolo
Hi David,
Ok, in this case, we're on the "on prem".
Like 2 people like this
David Niro
Perfect!
You will want to add a Group Generator to your structure and select the Attribute option.  In the Group By list, select Formula.
use this formula:
WITH ALL_ISSUES =
COUNT#subtree{issuetype}
WITH DONE_ISSUES =
COUNT#Subtree{
IF(statuscategory = "DONE";1
IF issuetype = "Epic" AND ALL_ISSUES = DONE_ISSUES:
"True Closed"
ELSE:
"Open"
Basically it compares the number of issues against the number of issues that are "done" and assigns text value "True Closed" to the Epic if the two values match and "Open" if they don't.
Please let me know if it helps!
Best,
David
