Jira Subversion Plugin installation error.
Mohammed Rashid
Getting the below error when i install JIRA Subversion plugin in JIRA 5.2.7
Could not find a handler capable of installing the add-on at atlassian-jira-subversion-plugin-0.10.11.1-distribution .zip. Check that the file is a valid add-on.
~Rash
Immanuel Siagian
April 1, 2013
Hi Rash,
The subversion plugin is a version 1 plugin, and therefore, it should be installed by placing the jar files (the jar files that are extracted from the downloaded zip), and place it on the JIRA's WEB-INF/lib directory. You would also need to add the subversion-jira-plugin.properties file into JIRA's WEB-INF/classes. Make sure that you have restarted your JIRA instance once you have added the mentioned files.
You can also extract the subversion plugin zip file and locate the README file for the installation steps. You may also find the steps from this link (Look under Install Instruction): https://ecosystem.atlassian.net/wiki/display/SVN/Subversion+JIRA+plugin
Hope this helps.
Theinvisibleman
March 31, 2013
Hi Rash,
May I know how exactly you tried to install the plugin? Did you try it by searching for an add-on and then installing it directly from UPM, or did you upload the file into UPM?
Joe
Mohammed Rashid
Joe,
I downloaded the zip file from marketplace and uplaoded in UPM.
When i directly try installing by searching from UPM, its shows that it cannot be done.
~Rash
Onkar Ahire
April 1, 2013
You have to go through the steps given in the documentation above, not by UPM.
Onkar Ahire
March 31, 2013
You might install via UPM. Please follow installation instruction given in below documentation
https://ecosystem.atlassian.net/wiki/display/SVN/Subversion+JIRA+plugin#versions
Mohammed Rashid
I was trying with UPM itself.
Help us plant more trees
