Jira Testing
Ky M
Hi.
May I ask how should we use test cases?
Should we try our best to reuse the test cases, or should we "tailored-made" for each of the Jira tickets?
Thanks.
Tomislav Tobijas _Koios_
December 2, 2024
Hi @Ky M ,
I feel like a bit of context is missing here. For example, what exactly are you testing? Is it your product, CR development, platform migration or something completely else?
I can't say if there are any best practices when it comes to that, but as with everything, it would probably be a good idea to try to reuse what you already have.
When it comes to test cases in particular, it also depends if you're using Marketplace solutions for that, or if you've built something via native features (such as specific issue types or Assets objects).
Tom
Ky M
I would like to use test cases for Jira tickets. For example, when I have an update on a button in an application, I have to test whether the function of it works as expected.
I would like to make a Jira ticket of type "Test", so I can provide a detailed procedure for my teammates to test. However, based on what I know, we have to build a release in Jira, then in the "Test" page, create a cycle beneath the release.
I would like to ask whether it will be a good practice to reuse the test cases more, or it will be better if we tailored made every test cases.
December 5, 2024
Ah, I see you're using Zephyr product from SmartBear. To be honest, I've never dug too deep when it comes to test cases with those apps, although I know some of our clients use Zephyr Scale for example.
From my experience, it depends on the things you need to test - for example, if you have a specific product where in each hardware/software version you would need to test the same things (+ additional features that came with the newest version), you would probably make test cases that can be reused.
On the other hand, some test cases will require to be 'mapped' 1-on-1 to Jira issues if these issues/items are quite specific.
When I think about it, I've seen cases/sites where in 1 Jira project, test cases (TCs) are mapped 1-to-1 on Jira issues, and in another project, users would reuse TCs as much as possible.
Like Ky M likes this
Andy Barbet
Hi @Ky M
I'm guessing you're using Zephyr Squad.  I'm familiar with the Scale version but not Squad.  Smartbear has user communities which are better for these types of questions as you'll get answers from users of the product.  I've added some links below that should help, and one for The Scale community in case you are a user of that - in which case, I'll see you in that forum!
Category: Zephyr Squad | SmartBear Community
Academy | SmartBear Software <--- this is the Squad 'Basics' training course
Category: Zephyr Scale | SmartBear Community
Like # people like this
Ky M
Great! Thanks you all a lot!!
Bogumiła Jarosik December 3, 2024
@Ky M If you are looking for a tool to manage test processes then I recommend you to try a dedicated application for this, such as Requirements and Test Management
takahiro.a.tsuchiya December 2, 2024
This might be work fine if you want to manage test cases more efficiently.
Zephyr Scale - Test Management for Jira | Atlassian Marketplace
