Jira Timesheet Reports display all users
Steven White May 28, 2014
Hi
Hoping someone here could help with a question on the Jira Timesheets Reports, i've done a search on the Jira's Online help but cant find the answer (but will admit i could have missed it).
When running the Time Sheet Report, can i list all users (or atleast list display more than one user at a time)? When every i've tried adding more users into the "User" field it only gives me the results of the first user entered.
Jira Timesheet
Steven White May 29, 2014
Didn't change, but have found can get the information accounts need from the Project Pivot Report
Mehmet Kazgan
May 28, 2014
Are you using the commercial plugin?
its a trial of the commercial plugin
Mehmet Kazgan
May 28, 2014
There should not be a different set of groups. Likely the plugin does not communicate with the users. What I would do is:
1. Go to the add-on
2. Disable it
3. Enable it
4. Do a full reindex
That should help. If not you can just uninstall and reinstall the plugin and reindex.
Hope that helps.
Mehmet Kazgan
May 28, 2014
If you need more users, you need to create a group for teams and that way you can display multiple users in one list.
I was thinking that myself, i have already created groups for departments, project teams etc... under the user manager, but they dont appear on the "groups" field for the time reports. Is it a different set of "groups"
