Hello All,
I have a query on how can i upgrade my current jira instance(i.e jira 4.3) to Jira instance (i.e jira 5.2.8) on new server.
First Approach:
take XMl backup of jira 4.3 and directly import it on jira 5.2.8 (and copying attachments and other avatar folders) on new server.
Second Approach:
take XMl backup of jira 4.3 and install new jira 4.3 instance on new jira server and do the Xml import, after that perform a jira upgrade on new server to jira 5.2.8,(and copying attachments and other avatar folders)
Please Give feedback,,
Thanks and regards.
Only second variant :)
take XML
install 4.3 on a new server
import and run 4.3 with all data, check it works
upgrade
Thanks for your Quick reply i will go with your answer.. :)
