with jira 9.11.2 we are no longer able to see Workflow on Chrome version 120.0.6099.200 (Official Build) (64-bit). Anybody facing the same?
The problem seems to be in The Scheduler add-on, at least in its 6.6.0_B version which we were provided to fix another problem. Plugin developers have identified the problem and will fix it but I am not sure when. Currently our 6.6.0_B is more recent than the latest released version.
Hello @Kalle Narinen ,
I've tested from my environment with the same versions as yours and I was able to see the workflow diagram from my side:
If none of these work, if you have a cloud instance raise a support behalf on the cloud instance and mention the issues with your server site, since Atlassian is not supporting the server anymore.
BR,
Nikola
hi, Ignito behaves the same
OS is Windows
Developer tools give these errors:
Hi Nikola,
Looks like at least in the screenshot you have a different view open than the reported one. In this case it was the "view workflow" functionality on issue view, not in administration / workflows side.
However, "view workflow" works for me in another environment so seems to be something specific to this environment.
- Artem
Learn more
