Jira Workflow Toolbox Set Assignee on create
webspin June 25, 2018
Hi I am trying to set the following rules on issue creation
If an assignee is selected then the issue should be assigned to the user selected
If no assignee is selected the issue should be assigned to the reporter
Ollie Guan
June 25, 2018
Max Foerster - K15t
June 25, 2018
Thanks for pointing @webspin to our documentation :D
Max Foerster - K15t
June 25, 2018
Hi!
to meet your needs please use the Set a field as function of other fields post function in the Create issue transition using the following settings rule to check and set the Assignee field:
(^$)%{00006}
where %{00006} is the field code for Reporter.
Best, Max
webspin June 26, 2018
Hi Max, thanks. it works except if you dont choose an assignee it assigns the issue to the project lead
David
Max Foerster - K15t
July 3, 2018
Hi David,
please change your "Default Assignee" setting to "unassigned" on the "Users and Roles" administration page in your project settings. Otherwise this won't work and also having this set to "Project lead" makes no sense in combination with this post function. Hope that helps :)
Best, Max
webspin July 3, 2018
Thanks Max, as we have many projects and global setting is not allow unassigned there doesn't appear to be a way to set project lead to unassigned.
Thanks for your input
David M
Max Foerster - K15t
July 3, 2018
Hm, okay. That's not good. And the person being the project lead can be a normal assignee right? So we could never know wether user A being a project lead was selected by the user creating the issue or the system using the default assignee "project lead"?
