Jira automatic assignment based on custom field value
Bryan Karsh
July 22, 2012
Any quick tips? I know the groovy script runner is out there -- but my version doesn't have something for just assigning issues (though I see that some of the scripts, like the fast-track workflow listener, allows users to also assign an issue..)
Basically, when issues are normally created in this particular queue, it automatically gets assigned to the project lead.
I want to maintain this functionality, but I want the issue to be assigned to another user based on a value in a select list custom field.
Help much appreciated. I'm assuming some sort of listener is needed..?
John Chin
October 30, 2012
Hi Bryan,
Please give a try to this third plugin known as User Picker From Project Role - Issue Alternative Assignee.
Good luck
Bryan Karsh
November 5, 2012
thanks -- looks promising. :)
Alexey Paveliev
December 13, 2012
In custom script listener hooked on Create event you can use any of the issue fields, built-in or custom, to do what ever you want:
like assign to hardcoded person based on priority, issue type, etc.
Here an example of complete Listener class file you can modify for your task.
Many people are asking how to start with custom listeners, how to name a class, where to put a file, etc.
I hope this sample will provide some guidance. Just copy it to a file <class name>.groovy and copy to a place where groovy runner can find it (check out this answer)
import java.util.*
import java.sql.Timestamp
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.*
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.link.*
import com.atlassian.jira.event.issue.AbstractIssueEventListener
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.issue.CustomFieldManager
import org.apache.log4j.Category
import com.atlassian.crowd.embedded.api.User
import com.atlassian.plugin.PluginAccessor
import com.atlassian.jira.bc.project.ProjectService
import com.atlassian.jira.user.util.UserUtil
//rename your listener class as needed
class AutoIssueAssignerListener extends AbstractIssueEventListener {
    Category log = Category.getInstance(LoggerService.class)
    @Override
    void workflowEvent(IssueEvent event) {
        // only one central way...
        this.customEvent(event)
	ComponentManager componentManager = ComponentManager.getInstance()
    @Override
    void customEvent(IssueEvent event) {
	// set explicit to debug
    log.setLevel(org.apache.log4j.Level.DEBUG) // remove for production
	log.debug "Groovy Service Class name: ${this.getClass().getName()}"
    log.debug "Event: \"${ComponentManager.instance.eventTypeManager.eventTypesMap[event.getEventTypeId()].name}\" fired for ${event.issue}"
        // Here you should put any restrictions for this task like
        // only for special issue types or similar
	Issue issue = event.issue
    User user = issue.getAssigneeUser()
	if (issue.isSubTask()) {
		return
	def customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
	def cfCategory = customFieldManager.getCustomFieldObjectByName("Category") //use your custom field name here
	def category = issue.getCustomFieldValue(cfCategory)
	def userToReassign = issue.getAssignee()
	UserUtil userUtil = componentManager.getUserUtil()
	switch (category) {
	  case "One":
userToReassign = userUtil.getUserObject("jsmith")
break case "Two":
userToReassign = issue.getProjectObject().getLead()
break } issue.setAssignee(userToReassign) issue.store() } log.debug "Listener ${this.getClass().getName()} completed" } }
It is not tested. Just removed my stuff from working listener and threw in few lines of code that might be relevant to your task
Alexey Paveliev
December 14, 2012
Updated my answer with code sample
Nic Brough -Adaptavist-
July 22, 2012
Just to rule it out - I take it components aren't suitable? (i.e. assign to component lead)
Bryan Karsh
July 22, 2012
Unfortunately, that approach wont work due to how our solution is set up.
Let's build A Rovo Agent 🤖
Save your spot
