Created a button, that when pressed, will change the CSS of the page.
I had this working with a drop down list but wanted it to be a button so moved everything in my .js file to the .vm file and included a button.
Now it's not working. JS is not being called when button is pressed. Wondering what i'm missing:
VM file:
#disable_html_escaping()
<li id="test-menu">
<button class="aui-button aui-button-primary" href="javascript:changeCSS">Compress</button>
</li>
<script language="JavaScript" type="text/javascript">
function changeCSS () {
if(document.getElementById("ghx-board-name").textContent == 'test') {
$(this).toggleClass('btn_yellow');
$("span.ghx-extra-field.ghx-fa").css("margin-left", "30px");
$(".ghx-issue .ghx-extra-fields").css("margin-top", "5px");
$(".ghx-issue .ghx-extra-fields").css("display", "flex");
$(".ghx-issue .ghx-flags").css("left", "20px");
$(".ghx-issue .ghx-flags").css("top", "5px");
$(".ghx-issue .ghx-highlighted-fields").css("margin-top", "5px");
$(".ghx-issue .ghx-type").css("left", "5px");
$(".ghx-issue .ghx-type").css("top", "5px");
$(".ghx-issue-content").css("font-size", "12px");
$(".ghx-issue-content").css("margin-top", "3px");
$(".ghx-issue-content").css("padding", "5px");
$(".ghx-issue-content").css("display", "flex");
$(".ghx-issue-content").css("margin-bottom", "-30px");
$(".ghx-issue-fields .ghx-key ").css("margin-left", "30px");
return false;
</script>
XML file web-panel:
<web-panel key="ChangeCSS" location="com.atlassian.jira.plugin.headernav.right.context" weight="1">
<resource type="velocity" name="view" location="/js/menu.vm"/>
</web-panel>
Button doesn't have href attribute. Use onclick event instead. Change your button to:
<button class="aui-button aui-button-primary" onclick="changeCSS()" resolved="">Compress</button>
Still doesn't seem to be working.
this is my entire xml file:
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}" />
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<!-- add our i18n resource -->
<resource type="i18n" name="i18n" location="menu"/>
<!-- add our web resources -->
<web-resource key="menu-resources" name="menu Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="menu.css" location="/css/menu.css"/>
<resource type="download" name="menu.js" location="/js/menu.js"/>
<resource type="download" name="images/" location="/images"/>
<context>menu</context>
<context>jira.general</context>
</web-resource>
</web-panel>
</atlassian-plugin>
