Jira cannot anymore install plugins by marketplace
Xarkam June 1, 2018
for some time, jira do not know how to install or update plugins anymore.
Looking through the logs, I have this error line:
`2018-06-01 16:37:56,493 UpmAsynchronousTaskManager:thread-3 ERROR xarkam 997x305x1 18g9ebc 192.168.0.1,0:0:0:0:0:0:0:1 /rest/plugins/1.0/ [c.a.u.c.r.resources.install.InstallFromUriTask] Error downloading plugin from https://marketplace.atlassian.com/download/apps/1217129/version/1000140`
Download a plugin from the marketplace and then upload works fine but it is not very practical.
I suspect that jira will no longer be able to access the "web" because my application links do not work anymore.
I wonder what is the element that causes this dysfunction.
Thanks for your help :)
Xarkam June 1, 2018
Xarkam June 1, 2018 edited
Ok. So, the server hosting bitbucket, confluence and jira.
All services responde over internet: https://issues.osames.org
No firewall into server.
Bitbucket, confluence can access to marketplace (from the same server).
I do not know what to look for in Jira to find out more.
Edit: this is a resquest to markquetplace from the server using lynx:
$ lynx https://marketplace.atlassian.com/download/apps/1217129/version/1000140
Looking up marketplace.atlassian.com
Making HTTPS connection to marketplace.atlassian.com
Verified connection to marketplace.atlassian.com (subj=*.atlassian.com)
Certificate issued by: /C=US/O=Amazon/OU=Server CA 1B/CN=Amazon
Secure 128-bit TLS1.2 (ECDHE_RSA_AES_128_GCM_SHA256) HTTP connection
Sending HTTP request.
HTTP request sent; waiting for response.
HTTP/1.1 302 Found
Allowing this cookie.
Data transfer complete
HTTP/1.1 302 Found
Using https://marketplace-cdn.atlassian.com/files/artifact/2eef5e0d-03b4-4a38-8de0-4176fe0cb24a/jira-jigit-plugin-1.2.4.jar
Looking up marketplace-cdn.atlassian.com
Making HTTPS connection to marketplace-cdn.atlassian.com
Verified connection to marketplace-cdn.atlassian.com (subj=*.atlassian.com)
HTTP/1.1 200 OK
Mirek
It is not related to application links but more like a Internet access that must be allowed from JIRA server.
Alexey Matveev
June 1, 2018
Could you check that you have internet access from the host where the Jira instance is installed?
