Jira core together with JIRA Software license
Milen Drenski February 1, 2020
I have an on premise installation with 50 JIRA Core licenses. I want to extend it by 10 users, so that all 60 users can work on the same system, but I want that the additional 10 users also have the JIRA Software capabilities. Is that possible? Do I only need to buy additional 10 JIRA Software licenses and do I need to do any updates to the system or the existing JIRA core, has also the JIRA Software functionalities.
Thanks and regards,
Milen
Nic Brough -Adaptavist-
February 2, 2020
Yes, that's exactly what you need to do.  Add 10 Software users and that's all.  No updates or changes needed (assuming you are on Jira 7 or above, and have Software added to it)
Milen Drenski February 2, 2020
Thanks Nic!
John Funk
Hi @Milen Drenski  - I suggest you submit a Request to Atlassian support here:
https://support.atlassian.com/contact/#/
Choose the Billing, Payment and Pricing option from the dropdown.
thanks John, I will do that. I was just wondering if someone had similar case
