Dear all,
Fairly new to Jira, so hope I can get some support on below :)
Situation
I my project we are dividing work from epics to tasks, and then each team-member logs workhours to sub-tasks hereunder. I would very much like to be able to visualize how much each member logs in our forecast vs. actual dashboard.
I am however struggling a bit with the views on sub task level....
Current Status:
Currently I have a rich filter which is being used to gather all the relevant data.
In my dashboard I can show the total hours spend on each epic and underlying tasks as seen below:
The assignees of sub-tasks are however listed as unassigned (the big pool of hours 24w 1h), and only the creator of the overlying stories are listed in the overview.
Problem:
I can however not see the overviews for my sub-tasks as these are not linked to the epic...
I can get below where the sub-task are summed for each task. It would however be sweet if that could be split out so I could see the information for each sub-task or for the assignees of the sub-tasks.
Ideally I would be able to see how many hours each of our team-members logs to specific epics that way.
Is there any neat way to do this, that does not require paid third party apps?
Hi @Magges
welcome to the community!
Jira's built-in reporting capabilities can sometimes be a bit limiting, especially when it comes to time tracking. If you're open to solutions from the Atlassian Marketplace, there are a number of apps available that add more powerful views and reports to your Jira site.
As an example, reading through your use case, I feel you might like the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
With these, you can build a view like e.g. this in just a couple of clicks:
This is really just one of a virtually endless number of possible views and reports; you can also view and group by any other issue fields, configure different sum-up styles, etc. etc.
Best,
Hannes
Hello @Magges,
I am part of the Decadis team and I would like to propose a solution using the Two Dimensional Filter Statistics gadget of our app sumUp for Jira (Server / Data Center).
It is possible to group the time spent in tasks and their sub-tasks under an epic per assignee and per epic link with this gadget.
If you are interested in our app and need more information on how to configure the gadget, please, visit our documentation, create a request in our support portal or reply to us in this thread. We will be glad to help.
Best regards,
Vicente
Hi Vicente,
Thanks for the reply,
Would like to explorer first if there is any options that does not require third party apps :)
Kind regards Magges
Hi @Magges
Even I'm new to Jira Dashboards, but I've built 2 Dashboard so far, to clearly answer your questions, i need clarity for the below questions
