Jira filter component size
Ibrahim Erdogan March 10, 2022
i want to search for issues which have more than 2 components.
I tried: AND component = ("3"). Is there a way to write a filter which performces the way i described?
Fabio Racobaldo _Herzum_
Hi @Ibrahim Erdogan ,
welcome to the Atlassian community!
Unfortunately you can't do that. As a workaround, you need to create a scripted filed (through script runner) with a numeric value that return number of components for each issue.
So, you can filter based on that new field.
Hope this helps,
Fabio
tanks!
I got 1200 issues which i have to analyze. So doing this manually would take a lot of time. Do you think its faster with the scripted file thing ( i never tried that before, so i think it would take a lot of time either). What do you think?
KR
Ibrahim
Scripted Field, with code inside, will calculate this for you for all existing issues. You need just to spend time to setup this field and to write 5 lines of code.
Fabio
what should the code look like?
Do you have Script Runner app to setup a scripted field?
BTW, code of your scripted field should be :
return issue.getComponentObjects().size()
this should solve your issue.
Fabio
Thank you, i got everything now.
Like • Fabio Racobaldo _Herzum_ likes this
if it worked please mark my answer as accepted!
Register now
