Jira fully replicated instances
Mircea Cun November 14, 2013
Is it possible to have 2 or more instances of Jira, fully replicated - mirrored (some sort of load balancing) having identical projects, attachments, etc and as well having users work on both of them?
Mike
Jobin Kuruvilla [Adaptavist]
November 14, 2013
In that case, have a look at ConnectAll. You can use it to synchronize data between 2 JIRA instances based on pre-defined rules. You can request for a demo and see if it fits your needs.
Thanks Jobin, I'll have a look!
Hi Jobin, it is rather the second option, having 2 instances running in 2 separate ofices, users from each office connect to their instance , and the instaces are fully replicated. Thanks for answering !
November 14, 2013
Are you trying to solve the "High availability" issue? If so, you might want to wait a bit longer when the JIRA clustering solution will be releases (around mid next year).
Or is it one of those requirements where you have 2 sets of users login to the different instances and make changes which needs to be synchronized across the instances?
Register now
