[Jira] hide warning or error message when creating issue from url
Xavier
October 29, 2018
Hi all,
is there a way to have a Jira issue creation screen without error message ?
I explain.
I use a Confluence page to create a Jira Issue via an url ie:
https://jira/CreateIssueDetails!init.jspa?pid=mypid&issuetype=myissuetype&customfield12400=xxx
My creation screen contains some required field that I can't prefilled. So, errors appears
This is normal.
But is there a way to hide those error on the top of the screen (just have the error below each required field) ?
Thanks in advance.
Regards
4 votes
Payne
October 29, 2018
We use a slightly different URL that doesn't show any required field warnings (though it does indicate them with a red *)
Instead of
https://jira/CreateIssueDetails!init.jspa?pid=mypid ...
try
https://jira/secure/CreateIssue.jspa?pid=mypid ...
Xavier
October 31, 2018
Hi Seal,
thanks, this is exactly what I need.
Xavier
Xavier
October 31, 2018
Hi Seal,
I just test your solution. It works but now, fields are not prefilled with values passed on url .
All my fields are empty.
Is it possible to combine both ?
regards
Payne
October 31, 2018
Yeah, all we pass is the project ID and the issue type ID. It seems that other field values cannot be passed; see and vote for https://jira.atlassian.com/browse/JRASERVER-23590
Xavier
October 29, 2018
Info: I need to let those field "Required". Just, is there a way to remove the "aui-message error" code inserted on top of page ?
regards,
deepali3031
Hi Xavier,
Were you able to remove the "aui-message error" code inserted on top of page, even when fields are required?
