Jira insights permission
Ziya Askar
January 31, 2022
In Jira INSIGHTS ,
We are storing applications. Each application has a technical owner.
We want only technical owners to edit/maintain their applications.
Is this possible?
It seems that if we give EDIT permission, they can amend all applications!
Thanks for feedback
Ziya
Melo
Hi @Ziya Askar, welcome to the community!
The permissions on Insight can be Global or set at the Schema Level and Object level. I'm assuming the "application" mentioned is an object type. I don't think it's possible to set permission for each individual object in this case.
More about Insight permission in the link below
https://confluence.atlassian.com/servicemanagementserver0417/configuring-roles-and-permissions-1072468628.html
Melo
Ziya Askar
February 1, 2022
That's right, it is OBJECT level. I was planning to give permission to application owners to modify their data only. Too bad not to be able to do this :(
